MP C4500 Intermittent fading
  • iscott
    • Mar 2010
    • 344
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: MP C4500 Intermittent fading
    I would remove the LSU shutter completely.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Counsel
      • Aug 2011
      • 529
      dirty or clogged mag roller, also clean the laser glass shield, could be bad corona wire and grid.
      • jonezy999
        just one copy??
        • Feb 2010
        • 952
        These machines use a charge roller, not a corona and grid.
        • Counsel
          • Aug 2011
          • 529
          ya i relized that after posting i though it was the mp4000 not the 4500, so forget what i said about a corona, i would definatly clean the mag roller though.
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            The MP4000 uses a charge roller aswell. As this is an intermittent fault I don't think the mag roller is at fault here, when the mag is caked up it is constant faded image. The issue is the laser shutter does not open fully every time the the machine prints. Just remove the shutter and you will be good to go.
            • Counsel
              • Aug 2011
              • 529
              Yes im am sure you are correct, and thank you for correcting me, the machine I had in my mind was the 5500, i don't know why I was thinking that, but I dont commonly go by the ricoh model #, most of the machines i have out there are gestetner labeled or lanier or by memory i use the code # very few have the ricoh numbers so I get confused on the forums as it seems almost everyone else uses the ricoh model for reference.
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                All good mate, not having a dig, just gets pretty confusing when a tech is trying to get a machine running and the advice they receive is of no relevance.
                This page may be of some use to you.
                Ricoh Equivalent Cross-Reference Guide - Free Shipping for Orders Over $199
                • Counsel
                  • Aug 2011
                  • 529
                  Thanks for the info, i was using either the tsrc site or my old goose guide that had an xref sheet but its a tad out of date. Good Help.
                  • mabawser
                    Tech
                    • Sep 2009
                    • 121
                    remove the laser shutter completly, had similar before and removed the shutter and never seen the fault again (supposedly a cam that opens the shutter jams)
                    • daveyt
                      • 15
                      Yep I agree, remove the laser shutter, we've had lots of problems. The shutter for whatever reason, doesn't open properly, and creates intermittent fading/deletions at one end of the page.
                      • wimps
                        • Mar 2012
                        • 16
                        This might be a shot in the dark, are the bushings that run the mac roller still there, I have had this happen to me where the previous tech had removed them to vac out drum unit and did not replace them
                        • Llama God
                          • Mar 2009
                          • 1353
                          Outstanding work, you should come and work for us!
                          • Masterchief
                            • Apr 2011
                            • 280
                            Well lets hope its not damage to the ITB or at worse some damage to the fusing balt as i have come upon before as these take time to repair
                            let me know how you get on....
                            PS have you tried printing off in all colours from the OP to eliminate Dev unit replacement on BK
                            Masterchief
                            sigpic
