Aficio MP2500 - SC 411
  • Polarbear
    • Feb 2012
    • 1070
    I have had about 4 instances of this on different machines of the same model machine.The machine starts up and reaches ready mode, without any problem, but as soon as one tries to copy/print anything (even a meter print), it stops with the error message.3 we have been able to get going, but this current one refuses to work.I have replaced HV board and discharge plate as per the manual, with no improvement. I have also checked for firmware bugs and upgrades but without success.I see there are several occurrences around the world, but no-one has posted a solution as yet.I would appreciate any help in this regard
    Press the GREEN button!!
  • Iommanxman
    • Aug 2009
    • 180
    Re: Aficio MP2500 - SC 411
    Might sounds like a long shot but have you tried swapping the fusing units over? I have had lots of weird and wonderful errors in the past that don't make any sense when it comes to HV errors. But rememeber the fuser and transfer are the most demanding on voltage so if you have swapped over the HV board I would start swapping the transfer, fuser and other units to see if that makes any difference....
    Just a thought....
    • Polarbear
      • Feb 2012
      • 1070
      @Iommaxman: Thanks for the thoughts.
      • Polarbear
        • Feb 2012
        • 1070
        Further testing has revealed that, disconnecting the Discharge cable from the Discharge power pack on the HV board, allows the machine to work (without the code) and without (so far) ill effects to the copies.
        We are doing some more testing though.
        • Clif
          • Jan 2007
          • 49
          Clean or replace transfer roller.
          • Kenvayne
            I had this one recently, the fault was exactly as you described, the problem was the transfer roller assembly, the contact terminal for the discharge plate housing breaks and allows the contact to push outwards from the housing and when the side is closed it shorts to ground. replace the transfer roller assembly and all will be fixed. see attached photos.Broken.JPG
            • Polarbear
              • Feb 2012
              • 1070
              Thanks man!
              I am sending this info to my tech supervisor, so that the field techs can take a closer look when they next get this!
              Thanks a million for the feedback.
              • mikadonovan
                • May 2008
                • 2931
                Originally posted by Kenvayne
                I had this one recently, the fault was exactly as you described, the problem was the transfer roller assembly, the contact terminal for the discharge plate housing breaks and allows the contact to push outwards from the housing and when the side is closed it shorts to ground. replace the transfer roller assembly and all will be fixed. see attached photos.[ATTACH=CONFIG]16928[/ATTACH]
                [ATTACH=CONFIG]16929[/ATTACH]
                You gotta like this. A new member helping out with his first post, even included pics. Good job Kenvayne.
                NEVER ASSUME ANYTHING
                • Athlontini
                  • Jun 2012
                  • 269
                  I love finding crazy (but completely legitimate) answers to emergencies like this. It's just another one of those things where you'd never guess it in a hundred years.
                  • Llama God
                    • Mar 2009
                    • 1353
                    There's always one smart-arse! Good work fella!
                    • longuetmariais
                      Thank you for your help (i didn't find more info on RICOH tech site )
