Ricoh MP7001 DF Jamming
  • kannuki2
    • Feb 2012
    • 398
    [Jamming] Ricoh MP7001 DF Jamming
    DF 062 -- Jamming code of 56, 006, 003 from SMC report -- 46 times
    1 sheet would get jam before it reaches registration sensor and it crunched up (I've replaced a whole pickup ass'y, torque limiter, sep roller and registration sensor), but after remove the jam it will run for 200 pages without a problem then it will start it again.
  • AyJayAreDii
    • Jul 2010
    • 99
    Re: Ricoh MP7001 DF Jamming
    I had one doing the a similar thing. If you remove the rear cover of the DF, look for the wiring loom that goes from the DF i/o board to the paper feed sensors. you may notice they cable tie the loom and the cable ties are very tight. I just cut of the cable ties and has an instant fix! maybe the wiring for the motor or clutch is to tight in the same way.
    • Counsel
      • Aug 2011
      • 529
      Also if Ayjay's suggestion doesn't work they did change the feed in covers on this model to a new design, its in the bullitins might be something to look at if you don't another cure.
      • Max
        • Oct 2011
        • 557
        clean all the patches 1st,specially the 2 under neath once.If not it will be the 2 wire looms that run from the board to the left cover of the Df (the one you open) ITs on Ricoh tech support tier 2.
        • Lagonda
          • Aug 2008
          • 1649
          Sorry to drag this one out of the cellar but I've got three of the buggers DF jamming with 03 and 54 codes. We've changed sensors, pick-up feed and sep rollers, rego and forwarding rollers and all the one-way bearings. About the only thing I haven't changed is the looms. Has anybody proved in the last 18 months that the loom is the problem?
