customer is getting jams from their bottom tray which is the 4th tray every few copies. this has been a problem ever since using leterheads, its fine on normal paper. i have changed the feed roller and the friction pad together but the after a months its starts jamming.
i have cleaned the black side roller when u open the lower right door and that seems to sort it. but the it jams again after a few days.
i have used the white friction pad which is mainly used on tray 2. but still jams
the lower door is fine and the magnets on the door are attached like they should. and the door hinges are not broken.
what is the white friction pad used for? why does tray 2 have a white friction pad? and the rest tray 1,3 and 4 have the brown pads.
