fax fowarding to email
  • jtymabel
    • Aug 2008
    • 164
    Ricoh MP C4500
    is it possible to set up fax fowarding to email as PDF instead of TIFF.?
    thanks
  • mikadonovan
    • May 2008
    • 2931
    Re: fax fowarding to email
    It appears you can only change the file format when forwarding to a folder. This is all I found in user parameters.
    NEVER ASSUME ANYTHING
    • blazebusiness
      SanDiegoCopierRepair.com
      • 1257
      Here is a link to all the manuals for your machine at Ricoh support. You might find something useful or not digging thru those user manuals. Hope the link is helpful.
      Aficio MP C3500/C4500 download page
      • mikadonovan
        • May 2008
        • 2931
        That's where I obtained that little tidbit from.
        • jtymabel
          • Aug 2008
          • 164
          scan can to folder it is then
          thanks
