I have a ricoh 2045 printer when it goes off, with the main switch to on. The car has 900000 prints. when you turn off the paper is jammed in the oven.
have been changed the power supply board and the oven, with the same problem.
the machine turns off after 50-60 prints. and lights up after 5-10minutes.
problem is not solved.
has anyone had this problem?
