aficio 700 no display and wrench and misfeed light flash every 5 seconds
  • axyun
    • Aug 2007
    • 1323
    Turn on aficio 700 and after 2 seconds the misfeed light flashes. Then 5 seconds(timed it) later the misfeed and wrench symbols flash together every 5 seconds. No display. Any help is appreciated as I have few parts for machine to swap out. Frank/ActionPhotocopy
  • mikadonovan
    • May 2008
    • 2931
    Re: aficio 700 no display and wrench and misfeed light flash every 5 seconds
    A blown FU102 on the PS Board will cause a no display condition.
    NEVER ASSUME ANYTHING
    • axyun
      • Aug 2007
      • 1323
      Thanks Mike. The wrench and misfeed flash every 5 secs als but I will check the PS board and bring fuses. Frank
      • sakura
        • 132
        700 series are SO old I can't believe someone still uses it. As I know there are no parts supplied to the market anymore for this model. get rid of it asap.
        • Jomama46
          • 2900
          Are you joking? There are still plenty of these old machines out in the field. And so far I haven't had any trouble getting parts from Ricoh.
          sigpic
          A+; Network +; PDI+
          • cleardata
            • Jul 2011
            • 137
            x2 here. if replacing the fuse wont solve it, try replacing the whole ps. i still have models like this that can still make good copies but if you can get a newer model than this, try mp7500.
