Ricoh MPC 3000 You don't have the privilleage to use this function.
  • saz_ryd
    • Jul 2008
    • 26
    [Misc] Ricoh MPC 3000 You don't have the privilleage to use this function.
    Hi,
    Could someone help me with this issue.When i am trying to do colour calliberation the msg appears You don't have the privilleage to use this function.
    Thanks and regards
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh MPC 3000 You don't have the privilleage to use this function.
    Machine administration is turned on. Log in with admin / no password to run ACC. If the admin password has been changed, log in as supervisor / no password to change it. If that's been changed too, do a search on the forum for password change. There's probably a few hundred threads covering the same topic.
    Hit it.
    • dv007833
      • Aug 2008
      • 43
      Dont mean to hijack the thread, but i have the same problem. However I dont see a login option in the system settings as you would normally see to get in as supervisor or admin. Any suggestions?
      • richoman101
        • Apr 2011
        • 19
        Try logging in through the web image browser its easier. Or do a forced line position through the diagnostics
        • Butrus
          • Jan 2012
          • 115
          I once had to replace the NVRAM,becouse all passwords where changed.
          Couldnt even log thru web image browser...
          It was the 3245 tho
          • Gift
            • Mar 2011
            • 2458
            I'm not 100% shure but I think you can reset the password for the A3245 out of the service program since this machine doesn't use one of the more recent controller generations that can't be resettet that easily.
            • Eric1968
              • 2458
              If you use the Factory login, you can change it.
              • Gift
                • Mar 2011
                • 2458
                OK - that would be the same as for the current models. I thought the A3245C is kind of "old enough" that you don't have to access via factory mode to see the SP.
                • pukiro
                  • Feb 2011
                  • 59
                  Originally posted by alamsandhu
                  i am just new with Ricoh i visited the customer found the same thing web password is not accepting as (admin/ supervisor) and customer wants to put job accounting on printing (color printing with with password and B/W printing without any account /no password
                  regards
                  M.Alam
                  if you cant log in using: admin & "blank" or supervisor & "blank" then your only have one option and that is to change the nvram!
                  p.s. dont forgot to upload the ram data before changing as this can cause even more issues!
