Savin 9025 ADF feed-in jams
  • callmefirst
    • Feb 2012
    • 51
    I have a Savin 9025 (50k), the adf jams almost everytime as the paper feeds in. If I raise the top cover and cheat the interlock it feeds in everytime. I replaced the clutch, no avail. The problem started when I blew out and lubed it because of a squeak. Any ideas would be helpful
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Savin 9025 ADF feed-in jams
    Did you get lube on the DF belt roller one way bearing or torque limiter?
    Hit it.
    • teebee1234
      • Jul 2008
      • 1670
      Not sure if this relates to your particular issue, but found this.....
      *I have also seen the original feeler get cockeyed and hang on the cutout it passes through.
