Ricoh mpc 2500 cannot set original orientation to one sided copies
  • yannii33
    • 121
    no matter what i try in copier function i cannot ser back the original one to one sided setting.
    it aurtomatocally duplexes the first two pages. the original problem was that it was sorting the copies 1 1 2 2 3 3 so i did a copier funtion memory clear and cant get it set to one side copying that button isnt available please help any advice really appreciated.
  • rthonpm
    • Aug 2007
    • 2854
    Re: Ricoh mpc 2500 cannot set original orientation to one sided copies
    Make all of the settings you want as default on the op panel, then press Program and select Program as defaults. Sounds like you want Single-sided as your duplex preference and sort turned on as well.
