Aficio 2015 error sc:982
  • slang
    Hi
    i have an Aficio 2015 that, for the second time, wont start: it tries to start, motor sometimes make a little turn but it stops immediately; no light in the display. Stand-by led is green but the machine does not responds to any button press.
    First time i changed PSU board and things went well for a month or so, but i think it was only a coincidence.
    This time i opened the copier, removed the CPU board (BICU), checked all connections, cables etc etc but all seemed ok.
    I re-seated the board in its place, reconnected all cables, powered the copier and, to my surprise, the machine started and tried to make the initialization routine, motor turned, display was on but after 5-10 seconds an error message was shown: SC: 982.
    This is an HDD error (i find an error list and 982 was: HDD construction error).
    But my copier has no HDD on board. So, what is this message?
    Can you help me?
    Thank you.
    Slang
    ps: forgive my bad english
  • imaginemoko
    unTrusted Tech
    • Jan 2008
    • 289
    try to place a HDD....
    fix the customer first then fix the machine... its simple and makes life more easy.
    • Cipher
      It's not easy being green
      • May 2006
      • 1309
      SC982 is not a HDD error, it's a NVRAM localization/area error.
      • slang
        Thank you for your answer.
        Very kind of you.
        Any suggestion to fix it?
        Slang
        • Cipher
          • May 2006
          • 1309
          You need you specify your area (SP5807) in SSP mode.
          And possibly the machines serial number as well (SP5811).
          • slang
            Thank you so much.
            The machine is up and running.
            Slang
            • Cipher
              • May 2006
              • 1309
              No problem, glad you got it going again.
              • copimen
                • Aug 2013
                • 8
                Re: Aficio 2015 error sc:982
                wow thanks Guys this also helped me a lot bt my meter reading went to oooooooo
                  • 37375
                  Originally posted by slang
                  Thank you so much.
                  Slang
                  And thank you for letting us know that it was resolved.
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Sounds like something reset your nvram: thats why your area setting went bust.
                    Press the GREEN button!!
                    • 4ndr01d22
                      hello,
                      im newbie here. google lead me to this forum, and i got the same problem from thread starter about Ricoh Aficio mp 2000 Error occurred: SC:982
                      i checked the (C) 107(c/stop) copy sp/mode/ the area is 807 and the serial is 811. it is ok with 3 digit only? for area and serial.
                      i dont know if i did it right but tell me about more posible fix. thank you very much.
                      sorry for my bad english.
