aficio 2238c sc-551
  • kanglee
    • Feb 2011
    • 7
    aficio 2238c sc-551
    Hi guys i'm have a problem with this aficio 2238c it's keep showing sc-551,and i'm already change another fuser unit and sc reset on sp-5810. Any suggestion ? thanks...
  • sandmanmac
    • 3983
    Re: aficio 2238c sc-551
    If you have replaced with a known good fuser, then it's probably the BCU
    • j morton
      • Mar 2011
      • 9
      SC551 is an improper temperature reading by the pressure roller thermistor. Check behind the fuser, I have come across machines that have had paper caught in the connector. If you have replaced the fuser assembly, I agree with Sandmanmac, next logical step would be the BCU.
      Most people believe that if it ain'tbroke, don't fix it.
      Engineers believe that if it ain't broke, it doesn't have enough features yet
