Maintenance mode on SP c232sf
  • Kings
    Steve@Kings
    • Nov 2009
    • 79
    [Error Code] Maintenance mode on SP c232sf
    Anyone out there know how to get into maintenance mode on a Ricoh SP C232sf.
    Ive got the service manual but it is as if Ricoh dont want to tell you how to access maintenance mode.
    Im trying to reset SC541 error after replacing the fuser assembly.
    Any help would be appreciated...PLLEEEEAASSEE
  • sandmanmac
    • 3981
    Re: Maintenance mode on SP c232sf
    My research looking through the SM seems to indicate you just press "user tools", "maintenance mode", "engine maintenance", "fuser SC reset", but never done it myself either
    • teebee1234
      • Jul 2008
      • 1670
      From the manual (SP section, not in SC section)....
      "Menu Mode" can be executed by depressing the following key sequence while in ready
      condition:
      Clear/Stop, 1, 0, 7 and Color Start. (Press and hold each key till a beep is heard.)
      • Kings
        Steve@Kings
        • Nov 2009
        • 79
        Thanks guys much appreciated........All sorted...
        • advcopy
          • Jun 2012
          • 25
          Originally posted by teebee1234
          From the manual (SP section, not in SC section)...."Menu Mode" can be executed by depressing the following key sequence while in readycondition:Clear/Stop, 1, 0, 7 and Color Start. (Press and hold each key till a beep is heard.)
          Thank you so much this has helped alother i replaced four fusers before i thought to reset it
          • nashua
            • Sep 2009
            • 25
            How to reset sc 220 in spc 242 sf any one pls guide
            • kannuki2
              • Feb 2012
              • 398
              this printer is shytttie. You have to download a Smart Organizing Monitor from Ricoh-usa website and installed it on a computer with 32bits OS, windows xp or seven 32bits.
