Ricoh mp 161 faxing
  • callmefirst
    • Feb 2012
    • 51
    Ricoh mp 161 faxing
    Ricoh MP 161 receives faxes but does not send to all numbers
  • ucinn
    • Jun 2009
    • 383
    Re: Ricoh mp 161 faxing
    error report codes? Good numbers that are actually fax lines? Not much to go on here.
    • Jomama46
      • 2900
      Are you plugged into "line" not "tel".
      On failed numbers, fax manually and listen before you start the xmission, this will generally tell you why the failure happened.
      sigpic
      A+; Network +; PDI+
      • rthonpm
        • Aug 2007
        • 2859
        Try turning off ECM: Fax SP 1-104-002, change bit 0 to 0.
        • Eric1968
          • 2458
          Did the customer pay his telephone bill?
