ricoh mpc6501- problem Tandem Tray
  • tullio
    • Feb 2012
    • 268
    #16
    Re: ricoh mpc6501- problem Tandem Tray
    se mi dai email,ti mando la stampa SMC.
    • Gift
      • Mar 2011
      • 2459
      #17
      no comprende
      • tullio
        • Feb 2012
        • 268
        #18
        same problem.?????????????????????????????????????????? ?????????????????????????????????????????????????? ??????????????????????????????????????
        • CableGuy
          Impulse Drive Engineer
          • Oct 2008
          • 417
          #19
          Hi
          I've seen this once before on a Pro 1357ex, obviously this one's a mono, but still it had the same on the display. I spent half hour taking it apart with no luck. Put it all back together and switch it off and on and it sorted itself. I think the machine just gets itself in a twist and needs to be restarted....
          Hope it's that simple for you
          Cheers
          • tullio
            • Feb 2012
            • 268
            #20
            in what way?
            then you solved it?
            • tullio
              • Feb 2012
              • 268
              #21
              [QUOTE=tullio;306683]in what way?
              then you solved it?[/QUOT
              broken display
