Printing problem on Ricoh mp2000
  • Gesttech
    • Oct 2009
    • 123
    Hi to all
    My problem was when client print on ricoh Mp2000sp, no print-paper get out & the green light in front dont lit.
    No password are set on printer. All network setting are good.
    But scan to folder & On web image is ok. i also check on usb no print get out.
    What are the problem & need replacement? The Controller board, Memory or sd card printer/scanner.
    Help PLs
    Thanks...............
  • rthonpm
    • Aug 2007
    • 2849
    Re: Printing problem on Ricoh mp2000
    Does the job log in the web interface show any errors? Check for user codes registered in the address book.
    • mikedci
      • Jul 2010
      • 227
      Check the driver and make sure its set to the correct port.
      Make sure you're using the correct driver...PCL/DDST.
      • sharpmind
        • Sep 2009
        • 478
        I have encountered the same problem in Aficio 2027.Only scanning was working.Replacing the memory and the controller board didn't work.So what I did, I replaced the NVRAM and it worked. Now my question is, have you tried to replace the NVRAM? Or, try to reload/update the firmware.
        • rsyarcia
          Hair Straightener Tech
          • 711
          agree! check the port and try to use pcl6,pcl5e,rpcs. Use a peer to peer connection to isolate the problem.
          Nobody is perfect..
          • Gift
            • Mar 2011
            • 2458
            If the machine doesn't print but scan doesn't neccessarily say that everything at the customers site is OK. Just hook up your notebook in case of doubt and see how it goes from there.
            If you're shure that the machine has a problem you can start with these steps:
            - updateing/rewriting the firmware as already suggested
            - Is the printer/scanner SD card in the correct slot? (slot 1 I think)
            - What does the status of the printer/scanner say in the web interface/mainpage
            - Performing all "memory clear" sub-SP's except enginge (SP5-8?? I think)
            • sandmanmac
              • 3979
              Originally posted by Gesttech
              Hi to all
              You didn't say whether or not the machine worked before, or what may have led to this problem?
              Have the NIC and USB ever been enabled?
              NIC:SP5-985-001 set to "1"
              USB: SP5-985-002 set to "1"
              Otherwise, I also agree with a memory clear as Gift suggested
              • Gift
                • Mar 2011
                • 2458
                Good hint - even if I don't know if you can access the web interface if the NIC is disabled.
                • Ricohlovers
                  • May 2009
                  • 59
                  That so true, you cannot use the scan function if the NIC is disabled.
