Aficio 3235C development unit is not set properly...
  • hossam
    • Aug 2010
    • 70
    i have a problem with aficio 3235C when switch the power on this message appears
    development unit is not set properly: yellow
    help please, thx
  • Saviour
    • 57
    Re: Aficio 3235C development unit is not set properly...
    Most of the times its just removal and replacing of the unit. But if it persists first I would insert the old unit and then make sure that you the new developer is the right one as the ones for AF3224 nearly fir but will give that error
    Voluntary assistance can be your greatest gift once you do not degrade the recipient.
    • Gift
      • Mar 2011
      • 2458
      Sometimes the development units have too much play so they move away from the drive. It's also possible that the dev clutch or the dev unit itself is broken of course.
      • sandmanmac
        • 3979
        I've had one recently where I had to run the "new unit set" SP.
        Open front cover, perform SP5-999-6 (yellow). Close cover.
        It's certainly the easiest first thing to try before replacing clutches, connectors, etc. (like i did before doing this)
