The was a used machine that I checked out in the office but didn't check the print scan. On delivery I couldn't pick up a DHCP address and even with a static IP could not ping the gateway or ping in. I connected my laptop with a cross over cable and couldn't connect that way either. I connected my laptop to the patch cable going to the wall and was able to connect to their network.
So I tested another controller board in another 2050 in the office and it worked so I took it out to the customer, installed it and got the same results!
I cleared the NCS setting in SP5801-11, reset the IP and still banging my head against the wall. When I replaced the controller board, I put the original 2 NVRAMs in the replacement board..
The controller is connected to the BCU but since the rest of the machine is working very well, I don't see the connection between the two.
I am hoping someone can think of something else to replace or try in lieu of replacing the BCU.
