SC 491
  • zeppelin fan
    • Jan 2011
    • 5
    [Error Code] SC 491
    DOES anyone know how to fix this code?Pcu's and dv's are not old.Thanks
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: SC 491
    what is the model?
    Nobody is perfect..
    • Polarbear
      • Feb 2012
      • 1070
      Re: SC 491
      Please supply the model number of the machine that is causing you this hardship, as it could be caused by several things depending on machine model.
      Press the GREEN button!!
      • Hemlock
        • 432
        Re: SC 491
        Addendum: Put the model number in the title - always.
        “Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'” (Isaac Asimov)
        • zeppelin fan
          • Jan 2011
          • 5
          Re: SC 491
          MPC3500
          • zeppelin fan
            • Jan 2011
            • 5
            Re: SC 491
            MPC 3500
            • zeppelin fan
              • Jan 2011
              • 5
              Re: SC 491
              Originally posted by rsyarcia
              what is the model?
              MPC 3500
              • Polarbear
                • Feb 2012
                • 1070
                Re: SC 491
                This is what Goose's Guide suggests:
                Drum/dev bias error - replace paper transfer unit
                Drum/dev bias error - replace high voltage supply unit
                Drum/dev bias error - replace drum unit(s)
                • nmfaxman
                  • 1702
                  Re: SC 491
                  High voltage power: Drum/ development bias output error
                  An error signal is detected for 0.2 seconds when charging the drum or
                  development.
                  􀂃 High voltage leak
                  􀂃 Broken harness
                  􀂃 Defective drum unit or development unit
                  􀂃 Defective high voltage supply unit
                  491 D
                  1. Check or replace the harness.
                  2. Replace the drum unit or paper transfer unit.
                  3. Replace the high voltage supply unit.
                  • Gift
                    • Mar 2011
                    • 2459
                    Re: SC 491
                    Can't we just delete such time-waster topics if people aren't qualified enough to start threads with some kind of minimum informations we need in order to give support, like:
                    - model?
                    - what issue/symptome?
                    - is it permanent/sporadically?
                    - already performed measures?
                    - PM status of the machine (in case it might be relevant)
                    Maybe, after some public brainstorming, a mod can write a little guide and make it sticky somewhere so at least we don't need to teach pre-school basics and re-invent the wheel all the time. Maybe it's just me thinking that these insufficiant threads are a growing phenomenon.
                    • RICOHTEC
                      • 42
                      Re: SC 491
                      [Symptom]
                      SC491 (High-voltage: Charge/Development: Output error) is displayed.
                      [Cause]
                      Drum (PCU + Dev. U) development unit is faulty.
                      [Resolution]
                      Replace appropriate drum unit.
                      [Symptom]
                      SC491 - high voltage supply and IOB are normal - no error found connectors or harnesses.
                      [Cause]
                      PCU Drum Stay Assembly not seated flush when closed - Yellow PCU not getting a proper drum ground connection.
                      [Resolution]
                      Disassembled Drum Stay Assembly (B2231300) - adjusted assembly so that it sits flush when closed and secured
                      The machine shows service call.
                      [Cause]
                      IOB is faulty.
                      [Action]
                      Replace IOB.
                      OR
                      Look for harness in transfert unit sometimes you can find a white wire broken.
                      • JustManuals
                        • Jan 2006
                        • 9838
                        Re: SC 491
                        Paul@justmanuals.com
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          Re: SC 491
                          - model?
                          Most people ask for help at Yahoo or Fixya first...where you can remain annonymous,ask your question and still leave just as clueless as when you went in.
                          I think people forget that the vast majority of replies here are coming from actual techs in the field....unlike Yahoo or Fixya etc.
                          • Dan G
                            • Nov 2014
                            • 56
                            Re: SC 491
                            such a hardship for you I'm sure. Just shut up and move on seriously
                            • sandmanmac
                              • 3983
                              Re: SC 491
                              You might want to consider checking the start date of this thread dude, and then perhaps browse the history and input of the contributor that you're so pissed off at for NO reason, and then tell us what makes you so damn awesome with your 4 big posts in as many years.
