USING SP MODE 5824 & 5825 in AFICIO 1035/2035
  • edwin206
    • Mar 2012
    • 36
    Hello ,
    With compliments to Copytechnet members ,I have received the MCE RICOH Software and lend a PC CARD A2309352 from one of my friends.
    Now I am facing problem to use SP Mode 5825.
    I have used 5824 to upload firmware of controller etc to PC Card_ executed "5824" and completed screen appears after some time.Subsequently I checked the PC Card with MCERICOH and saw that the card have 4MB data with a different checksum and saved that as a file in my computer_but unable to download that bin file to another unit of same model.
    I want to update a machine from ver 5.23 to 5.25.
    Is there any special setup to download firmware from PC Card to Controller.
    Procedure shown in Service tables of service manual did not worked
  • Gift
    • Mar 2011
    • 2459
    Re: USING SP MODE 5824 & 5825 in AFICIO 1035/2035
    That's not the correct procedure. These machines will load the firmware update screen itself if you turn them on (with the PCMCIA card inserted). SP Mode 5824/5825 has nothing to do with updating the firmware - it's just a backup feature for the NV Ram values. You might follow this checklist:
    - did you get the proper firmware files (for the proper model and the ending *.bin)?
    - did you use the MCE tool correctly (once installed it's basicly easy - I always select "erase card before write" if I prepare a card)?
    - do you have a compatible PCMCIA card (only 4MB cards are supported but not every 4MB card will work due to other specification issues - to avoid troubles it'S recommended to used a card purchased from ricoh)?
    • edwin206
      • Mar 2012
      • 36
      Hi,
      I have 4MB card A2309352 and "Elan PC Card Explorer 3.21" and I can erase /read/write /compare and explore the PC CARD easily.Even save the file uploaded to card from controller of machine to my computer as bin file (4MB).
      Unfortunately I have no bin files available seperately for AFICIO 1035/45 & 2035/45.I am need of Engine/BICU/NETWORK/LANGUAGE and other firmwares.One for 2022 was very kindly be supplied to me by Copymaker .Any help will be deeply appritiated
