Aficio 240W pulling from both rolls
  • mckircher
    • Sep 2011
    • 21
    [Jamming] Aficio 240W pulling from both rolls
    I have an Aficio 240W that will occasionally pull from the back roll when plotting to the front roll and leave a cut piece of paper in the cutter causing the jam condition. Last week, it was doing it with 17" in the back and 32" in the front. I swapped the rolls around and it worked for a few days, now it's happening again.
  • JustManuals
    • Jan 2006
    • 9865
    Re: Aficio 240W pulling from both rolls
    Paul@justmanuals.com
    • Polarbear
      • Feb 2012
      • 1070
      Sounds like the second tray may have a binding clutch, that causes it to feed when it shouldn't. Try swopping the feed clutches and see if the fault swops with it.
      Press the GREEN button!!
      • jdzr
        • 125
        Sounds like the second roll is not pulling back out of the knife assembly, then when the other roll is started it just drags the second roll into machine.
