Ricoh 2851 - How to Turn Off ECM ??
  • vontech
    • Aug 2010
    • 10
    Can anyone tell me the steps to take to turn off ECM for faxing? I can't seem to find it referenced anywhere.
  • mikadonovan
    • May 2008
    • 2931
    Re: Ricoh 2851 - How to Turn Off ECM ??
    On most models I've dealt with it has to be changed within the fax sp modes, bit switch programming, com switch 01, bit 0.
    NEVER ASSUME ANYTHING
    • rthonpm
      • Aug 2007
      • 2847
      Try fax SP 1-104-002. Change bit 0 to '0'. That will turn off the dreaded ECM and JBIG.
      • vontech
        • Aug 2010
        • 10
        I'm a bit of a copy noob. I do network and Desktop support, so I'm not untrainable.
        Can you walk me through from a noob's perspective on how to issue these commands?
        • vontech
          • Aug 2010
          • 10
          Thanks for the help
          • mikadonovan
            • May 2008
            • 2931
            Originally posted by vontech
            Thanks for the help
            Use the search function on the ricoh copier forum. There are multiple posts on service mode access and fax bit switches.
