Which Ricoh is Tally Genicom 8008 Color Laser ?
  • Butrus
    • Jan 2012
    • 115
    A friend f mine has this thing...asked to take a look at it and toner is running out also...
    From my memory Im shure Ricoh had printer exactly like that
    (I work on Ricoh mostly)
    What Ricoh model should I look for parts and toner ?
    Thanx
  • JustManuals
    • Jan 2006
    • 9838
    Re: Which Ricoh is Tally Genicom 8008 Color Laser ?
    It's not listed on the Katun site at Katun Corporation - World Wide printer Equivalency List for Tally
    HtH,
    Paul@justmanuals.com. I don't have this manual either.
    • exit148
      • Oct 2009
      • 44
      I just checked the Buyers Lab Guide & that TG 8008 is not listed there either.
      • ucinn
        • Jun 2009
        • 383
        Thanx
        I couldn't find a pic of it, but from looking at the supplies, looks like it could be the AC031?
        • Jomama46
          • 2900
          Find the metal manufacturers plate and see who made it.
          sigpic
          A+; Network +; PDI+
          • teebee1234
            • Jul 2008
            • 1670
            Ok, found a link to the manual here. Definitely the same as the Ricoh CL1000. I've attached the Product Support Guide that will have the supply info.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              HtH,
              BUT you can buy disappointment over this for $12.99 as an instant download
              • sandmanmac
                • 3981
                HtH,
                Wow...we all appreciate you weighing in Paul.
                "It's not listed (Here), and I don't have a manual either".
                Are you sure there's nothing else you CAN'T HELP WITH on this?
                • Jomama46
                  • 2900
                  Good job Teebee
                  sigpic
                  A+; Network +; PDI+
                  • JustManuals
                    • Jan 2006
                    • 9838
                    Well if it truly is the Ricoh G108, then that Parts & Service manual I DO have.
                    http://www.justmanuals.com/ricoh-pri...ual-p-237.html
                    • JustManuals
                      • Jan 2006
                      • 9838
                      Hey look, I tried to help the guy even though I originally thought that I didn't have the manual. I took time out from my day to do some research. You don't like it when I post my links and you don't like it when I try to help someone.
                      You need to remember that if it wasn't for me and the other guy (Neil) who pay to advertise here, you wouldn't have this site to post on. I also donate monthly to the cause.
                      • Butrus
                        • Jan 2012
                        • 115
                        Thanx ALOT!!
                        Its CL1000 for shure.
                        Came back to me when you mentioned it...
