Ricoh Afico 2105 shows lines in printing.
  • tinnyjay
    • Oct 2009
    • 655
    Hello!
    How are you?
    There are more than two weeks,Ricoh AF2105 makes some fine lines in almost 70 % of pages i print.
    Sometimes it shows error code SC355,wich means,drum potencial sensor error,laser error or drum error.
    I made a full service of it,changing developer,filters,drum,drum blade,corona wire and grid,tubes,fuser rollers and fingers etc.
    It worked perfectly 1 month making about 300 k without any problem,but now shows me some lines you'll see in my attachment.
    Something else to say.When i am copying copier freezes and looks like is working and in monitor it says "Copying" and in fact nothing is printed.At this moment,scanner lamp is always on.
    Maybe somebody of you experienced before this problem.
    "Who loves the roses,must also bear thumbs"
  • vargue
    • Oct 2011
    • 404
    Re: Ricoh Afico 2105 shows lines in printing.
    what about counter image .
    • RG1964
      • Jul 2009
      • 56
      Are there any lines in the 'white margin'? Black lines means the laser is writing. In my opinion it can be the laserunit or a bad hdd.
      Sounds like a SC990 might be in the smc report?
      • tinnyjay
        • Oct 2009
        • 655
        Yes,sometimes it showed SC990 but very rarely.
        • tinnyjay
          • Oct 2009
          • 655
          Solved!!!
          Bad scanner board!
          Thank you
