MP4000/5000 (D009-D013) 320k PM Procedure
  • verderacer
    • May 2008
    • 158
    Ricoh & Microsoft may pay the bills but Un*x saves my ass every day.
    MCSE/CCNE/ENS and other crap...
  • zed255
    How'd ya manage that?
    • 1024
    Re: MP4000/5000 (D009-D013) 320k PM Procedure
    I always run developer initialization first (SP2801) after ensuring all process values are at default, then I perform the rest of the PDCU codes.
    Also, even though the Ricoh doctor blade gaps are supposed to be factory set DFW items, I find that setting these to a snug 0.35mm gap helps reduce dusting and filming without sacrificing quality and does help get more life out of the developer. That said, 320k on dev is a pipe dream but 160k to around 200k is possible.
    • imaginemoko
      unTrusted Tech
      • Jan 2008
      • 289
      SP 2801 first then to follow the next 4....
      fix the customer first then fix the machine... its simple and makes life more easy.
      • verderacer
        • May 2008
        • 158
        Thanks for the info all. As soon as the rest of the parts are in I will be there... Gonna bring the feeler gauge and check out that gap too as it has me curious.
        In regards to default values, well its nearly 30k past its pm cycle and im sure the values are waning a bit as the cq is not that great but at least its not backgrounding.
        • Oze
          Ricoh Fanboy
          • Jul 2008
          • 1663
          I tend to return the charge roller voltage to default first...mainly as it doesn't involve a restart.
          Then the dev initalize.
