SR3020 on MCP4000 with staple exit jam Code 195
  • TCA TECH
    • Mar 2009
    • 104
    [Jamming] SR3020 on MCP4000 with staple exit jam Code 195
    Hi All,
    I have an issue with a SR3020 on MCP4000 with staple exit jam Code 195
    I have updated firmware, replaced exit sensor, Exit gate lift motor, exit gate feed motor, controller PCB, tray sensors.
    195 code states exit sensor not detewcting paper as feeds out. test in iput mode ok. work fine in proof and booklet mode and no staples.
    help
    Copiers are only as good as there last service
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: SR3020 on MCP4000 with staple exit jam Code 195
    Does the paper skew in the finisher? I have seen the springs behind the white plastic float rollers fall out and cause jams in the path towards the stapler.
    Also check bulletin RB222015d. It has a firmware upgrade for jam 192,193 & 201. This bulletin does seem to relate to an intermittent fault where it sounds as if your fault is constant.
    Can you perhaps post a plotter jam history?
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Llama God
      • Mar 2009
      • 1353
      How are the sponge rollers at the exit?
      • TCA TECH
        • Mar 2009
        • 104
        Sponge rollers new, but only used when sorting
        Firmware up to date.
        No skewing evident
        Jam code is all 195 which is no paper detection at exit sensor, but checks ok in input mode
        • TCA TECH
          • Mar 2009
          • 104
          Problem caused by binding on the foam rollers and idlers to the belt on exit. This just put too much load on moter that stopped with the slightest amout of extra resistance. Only found after I replaced everything else
          Intermittent with thicker staple jobs worse.
          • bpvinson
            • Apr 2013
            • 4
            So was this resolved by replacing the feed out motor in the finisher?
            • TCA TECH
              • Mar 2009
              • 104
              No the motor didn't actually fix, it made it better(or thought it made better) for a while. It was the foam rollers on the stacker. I dismantled cleaned put a bit of silicon and never played up since
