Hi guys,
I have being having an issue with an adf feed in problem on this machine on and off for a while now, the paper feeds up to the first set of rollers ( not always) and stops just as it reaches them, you can see that the paper is being feed by different amounts if watched carefully, its as if the feed belt is not gripping the paper enough.
I have changed the feed belt, shaft, pick up rollers and most one ways at the back that are responsible for the operation of the feed in shaft, any ideas??
(i will check if i have missed any one ways out but im sure they have all been fitted)
Thanks.
Thanks.
