MPC4500 CRAPPY PHOTOS
  • mikadonovan
    • May 2008
    • 2931
    I have a B222 in the field that just started this problem. The good print is from a 4500 in shop for comparison. The not so good print is from the customer. Identical settings, as far as I can tell, same PCL6 driver used with identical print settings. The photos are really washed out. 28% on pcu's, 75% on developers. Here's the kicker. I can lay a photo on the glass and make a GOOD copy of it, so the problem is only when printing. Scratching my head on this one. Performed ACC, no effect. SP mode printer test page is excellent.
    NEVER ASSUME ANYTHING
  • rsyarcia
    Hair Straightener Tech
    • 711
    Re: MPC4500 CRAPPY PHOTOS
    have you performed the force line adjustment?
    Nobody is perfect..
    • mikadonovan
      • May 2008
      • 2931
      Uhhhhhh, no I did not. Might be a good idea. Is it Friday yet?
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        After the LP adjustment / if it passes enter sp mode. execute sp 5610 then do auto color cal in user tool/maintenance.
        Mystic Crystal Revelations
        • teebee1234
          • 1670
          Have you tried playing around with the Quality settings in the driver? The default may be set to something like Speed or High Speed (change to Quality), 300/600dpi. You should find the ability to set to Photographic, High Quality, 1200dpi. Depending on the driver (RPCS has the most quality adjustments available), you may find choices like General Documents, Photograph, DTP and CAD. The RPCS also has Color Balance Adjustments (brightness, contrast, saturation and color balance) in the Custom Settings. PCL drivers usually don't have quite as many adjustments but enough to make a difference.
          • Herrmann
            • Jan 2006
            • 792
            Just a shot in the dark: you said, that you have the same mashine availible at your shop, i would try to interchange the controllers at first to see, if the problem is mashine related or driver/settings related.
            second shot in the dark: what happens if you try different drivers like pcl5 and rpcs?
            If sometimes you feel a little useless, offended and depressed always remember that you were once the fastest and most victorious sperm of hundreds of millions!
            • Gift
              • Mar 2011
              • 2444
              Yes you can only compare if you ensure that bot machines are printing with the same driver settings. Another hint: Check the user tools - there's a "4 color mode priority" setting somewhere within the printer options in user tool. You can switch it between "photo" or "text" iirc. Switching the setting to text does usually decrease the overall quality.
              • mikadonovan
                • May 2008
                • 2931
                It was a matter of a single box in advanced print options being unchecked. Don't know if the latest update changed the default, or what. A simple but time consuming fix. Thanks for the replies.
