Ricoh MP 4000 ?'s about scan option settings and screen.
  • Desert Rat
    • May 2008
    • 1089
    I just installed this machine and this customer does a lot of scanning.
    The trouble he is having is this. They need to scan files to different folders using the same
    file name. The same file will need to have different parts of the file sent to different folders.
    On the their Savin 8045 (Aficio 3045) the file name is held in the window long enough for
    them to accomplish this task.
    I went through the screens yesterday looking for anything that might give a clue.
    Today I will have to find time to read the scan op manual, unless someone knows
    what setting I am looking for.
    Also the screen, does not seem as sensitive as on the 8045. I will run the touch
    calibration today and see if that helps. That seem to be off a little also.
    DR
  • Gift
    • Mar 2011
    • 2459
    Re: Ricoh MP 4000 ?'s about scan option settings and screen.
    Check Scanner SP - theres a sub-SP Mode calles "User Info Release" (or something like that). Change this setting to 0 (or "no").
    If the touch screen responses badly you might have to replace it - it's a known issue and the touch screens have been modified (you can detect a modified one if the end of the flat-cable has a white connector - the old one are brown-coloured).
    • Llama God
      • Mar 2009
      • 1353
      Liking the vast majority of this, although I'm not sure whether it will release the file name after the first job anyway. It may be your only hope though!
      • Gift
        • Mar 2011
        • 2459
        It's probably some kind of discretion reasons, too
        • Desert Rat
          • May 2008
          • 1089
          Thanks for the reply. I ran the touch screen panel calibration program and that seemed to
          cure the problem. As far as the program you mentioned, thanks I should be able to find
          something about it in the book.
          DR
          • Gift
            • Mar 2011
            • 2459
            I think you'll discover it even without the book since it's no cryptic bit switch or whatever - there aren't that many SPs within "Scanner SP"
            • mikadonovan
              • May 2008
              • 2931
              cure the problem.
              Unfortunately if it is the old style screen, the calibration won't hold long. Replacement is inevitable.
              NEVER ASSUME ANYTHING
              • Desert Rat
                • May 2008
                • 1089
                Yes, i've heard about the touch screens on these models. I have not taken it apart to see
                what color the conncetor is yet. I will wait untill I notice it again.
                • Desert Rat
                  • May 2008
                  • 1089
                  I have had no luck finding this setting. I must be missing something.
                  Any help would help.
                  DR
                  • Jomama46
                    • 2900
                    On the C2050 it is Scanner SP1-1012.
                    sigpic
                    A+; Network +; PDI+
                    • sandmanmac
                      • 3990
                      DR
                      Just as Gift ( and I just realized Jomama) said:
                      User info Release: Scanner SP1012
                      • Llama God
                        • Mar 2009
                        • 1353
                        As it is on the MP5001. Having scoured the MP5000 manual I can confirm that I am either blind or stupid.
                        It's called "User Info Release" by the way.
                        • Desert Rat
                          • May 2008
                          • 1089
                          Could I have the wrong book? The book I have is for these product codes.
                          "Model AL-C1 Machine codes D009/D011/D012/D013." from the first page
                          Scanner service programs start with a SP4-xxxx in my book and there are 3 of them.
                          There are SP1-xxx feed 1
                          Then is SP1-xxx feed 2
                          and SP1xxx feed 3
                          It goes on like this for SP-2xxx drum 1, 2 & 3
                          SP-3 xxx process only has the one. Next is the
                          SP-4 xxx scan 1, 2 & 3 all the programs start with a "4"
                          And 5 for SP-5
                          1 for SP-6
                          2 for SP-7
                          5 for SP-8
                          I am close enough that I can go and double check the machine codes and look through
                          the scan program on the machine.
                          But this seems weird to me.
                          Thanks for the help
                          DR
                          • Llama God
                            • Mar 2009
                            • 1353
                            Go into SP Mode and then select Scanner SP, not System.
                            • Gift
                              • Mar 2011
                              • 2459
                              Go into SP Mode
                              that's right and mentioned before 3x
                              He probably confused it with the other scanner SP (within system sp). Imagine this guy playing point & click adventure games...
