Ricoh P7575 Laser Printer
  • brunot
    • May 2012
    • 148
    [Error Code] Ricoh P7575 Laser Printer
    Intermittent problem : SC 300
  • Eric1968
    • 2458
    Re: Ricoh P7575 Laser Printer
    Replace the charge corona unit. If that doesn't work, replace the charge corona power pack.
    • rthonpm
      • Aug 2007
      • 2859
      That would be a corona error. Check the charge corona unit and the wiring for it. More than likely you'll need to replace the corona unit.
