MP4000 ARDF JAM
  • hmac
    • Aug 2009
    • 129
    MP4000 ARDF JAM
    Hello,
    I have a jam in the DF of a MP4000. The jam occurs only with two-sided originals. The sheet stuck on the back, at the time of the back scanner.
    The sheet is not to offend, it just stops and the wheels continue to rotate for about 20 seconds, then displays its jam. During it's 20 seconds I can open the hood, pull the sheet, or do what I want, DF continues to turn as it nothing had happened.
    Firmware: OK
    Wheels: OK
    No foreign body in the DF
    I clean all detectors
    I can not find the fault!
    _________________
    HMac.
    _________________
  • Polarbear
    • Feb 2012
    • 1070
    Re: MP4000 ARDF JAM
    Where is the page getting stuck? Is the original page damaged during the jam?
    Sometimes the junction gate stick, that is supposed to open and let the page go to the middle roller set, which lets it feed back for the machine to be able to scan the rear side.
    If it sticks partially open, the paper will collide with it, and the machine will still attempt to feed the paper, for the period you describe, until it times out and registers a jam.
    When the junction gate sticks closed, the page would feed straight through as if it was a single sided copy, and as soon as the page lands in the lower part of the df, it will register a jam.
    Press the GREEN button!!
    • Gift
      • Mar 2011
      • 2459
      Re: MP4000 ARDF JAM
      That's a good question - hard to tell without knowing if the paper looks jammed or just seem to stop in the paper path for no reason.
      • hmac
        • Aug 2009
        • 129
        Re: MP4000 ARDF JAM
        The paper is not damaged. The sheet hangs at the back for the second scan, when it is at higher level of the rollers. She stops and the wheels continue to turn. Then jam.
        _________________
        HMac.
        _________________
        • teebee1234
          • Jul 2008
          • 1670
          Re: MP4000 ARDF JAM
          What is the jam code?
          • Llama God
            • Mar 2009
            • 1353
            Re: MP4000 ARDF JAM
            And is it the same jam code every time? I'd check the sensors in input mode.
            • hmac
              • Aug 2009
              • 129
              Re: MP4000 ARDF JAM
              I tested all the detectors in Input Mode. It all work. I really do not understand!
              The jam occurs randomly. But I notice that when I support slightly on the door of the ARDF jam occurs, even in single copy. And the leaves are located exactly in the same place when I jam the duplex.
              So I check the door, detectors, and the guides are but I do not see anything unusual. Have you ever had this down?
              tomorrow I will provide you with pictures of the place where the leaves are blocked!
              _________________
              HMac.
              _________________
              • hmac
                • Aug 2009
                • 129
                Re: MP4000 ARDF JAM
                Where do I see the code of jam?
                _________________
                HMac.
                _________________
                • Llama God
                  • Mar 2009
                  • 1353
                  Re: MP4000 ARDF JAM
                  SP7xxx
                  • jonezy999
                    just one copy??
                    • Feb 2010
                    • 952
                    Re: MP4000 ARDF JAM
                    Another question
                    Are there still originals left on the feed table to be scanned when the jam occurs or does the jam occur once the last original is scanned?
                    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
                    • Polarbear
                      • Feb 2012
                      • 1070
                      Re: MP4000 ARDF JAM
                      Sounds to me like something is bent or out of alignment. We had someting similar and it turned out that the df was not sitting square on the scanner and some papers would get caught when leaving the slit glass area and entering the entrance of the df (next to the platen sheet). Re-aligning the df solved that.
                      It could also be that the entrance I mentioned above, is not equally wide on both sides, which could also cause misfeeds.
                      • Zeldaman
                        • Mar 2011
                        • 946
                        Re: MP4000 ARDF JAM
                        Hi there!
                        Jam-problems occure often if the main-hinge of the DF "stay in the air", meaning if you make copies without the DF and then close it, the rear corner of the feeder is not completly down on the frame (-3 mm) then jams or dogears occurs. Take 2 thick washers beetwen the screws and springs on top of the hinge and oil all movable parts carefully. Good luck!
                        Greetings...
                        • jonezy999
                          just one copy??
                          • Feb 2010
                          • 952
                          Re: MP4000 ARDF JAM
                          Originally posted by Zeldaman
                          Hi there!
                          Greetings...
                          Good trick you suggest here. Although I don't believe it will help this particular issue. You should start a new thread for most Ricoh ADF's. I don't think it's been mentioned here at CTN before.
                          • hmac
                            • Aug 2009
                            • 129
                            Re: MP4000 ARDF JAM
                            Originally posted by jonezy999
                            Another question
                            Yes there are still on the original tray. Here are photos of the jam.
                            _________________
                            HMac.
                            _________________
                            • NeoMatrix
                              Senior Tech.
                              • 3513
                              Re: MP4000 ARDF JAM
                              Take the Platen glass out of the machine. (So you don't break it).
                              ::: Facing the machine :::
                              Grab the document feeder main mounting frame from the left front corner and lift the document feeder until you bend or pop the darn ADF metal mounting frame back straight.
                              Place the glass back into position and check that the glass sits perfectly flat on every corner. If the glass piviots slightly repeat the above.
