Ricoh MP C3300 Duplex Lead edge registration adjustment help
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    I am having a duplex lead edge regsitration issue on a Ricoh MP C3300.
    Please see the attached image for the second side which i need to centralise. . . note that this is the second page going through the ADF.
    As you can see in the image that you can see the trailing edge line and the image is all the way to the left.
    Can anyone let me know which SP adjustment I need as there seems to be quite a few!!
    Many thanks
    Ricoh MPC3300 second side.pdf
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: Ricoh MP C3300 Duplex Lead edge registration adjustment help
    user tools-printer features-edit-set all values to 0mm.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • Gift
      • Mar 2011
      • 2459
      all-time classic, still I don't get it why ricoh still use these settings as default since probably every dealer set these values to zero in order to avoid calls.
      • sandmanmac
        • 3982
        I know it was just a brain fart Jonezy, but I believe it is actually: user tools- Copier/document server features - edit - set all to 0mm
        • Jomama46
          • 2900
          That's the one.
          sigpic
          A+; Network +; PDI+
          • jonezy999
            just one copy??
            • Feb 2010
            • 952
            Or just drunk like usual.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Hmmm.....beer induced Alcoholzimers
              • jonezy999
                just one copy??
                • Feb 2010
                • 952
                It's nearly 17:00 and time to do it again haha.
                • fbkhan3
                  • May 2012
                  • 421
                  [QUOTE=jonbonse;290604]Hi all
                  Many thanks
                  SP Mode -1001/13 for duplex registration
                  SP mode- 6-xxx for front and back in duplex mode
                  hi there.it seems trailing edge problem,but first you need you to make sure is it problem with DF trailing Edge or duplex registration,first you need to make a double sided copy from scanning glass,if it's ok then go to SP Mode/6-xxxx pheriphs/ DF registration Adjustments for duplex front or back,
                  If it's same with scanning glass,SP Mode/1001 Leading edge registration,13 duplex plain,thick or middle thick,default value is 0.0.set it higher make a copy and check copy.its tricky but surely make a difference,
                  hope you get it!
