mp4500 jam 66
  • ash_572
    • Oct 2008
    • 523
    mp4500 jam 66
    jam code 66= exit sensor off
    i have only seen it jam when duplex. simplex is ok.
    paper just seems to stop half way through the exit rollers while the exit rollers are turning. sometimes the first copy comes through fine.
    i removed the bridge unit, swapped the interchange unit and duplex unit. all rollers cleaned.
    fuser unit has been rebuilt with brand new parts.
    the sticky pads inside the interchange unit have been removed although the solenoid wasnt sticking anyway.
    paper jams half way out of the internal tray. sometimes it comes through fine but most of the time it stops halfway through the interchange unit
    any one out there that can help me please
  • ucinn
    • Jun 2009
    • 383
    Re: mp4500 jam 66
    I have seen the exit switch in the interchange unit cause this.
    • ash_572
      • Oct 2008
      • 523
      Re: mp4500 jam 66
      the exit switch?? u mean the side door switch?
      • ucinn
        • Jun 2009
        • 383
        Re: mp4500 jam 66
        My bad..exit sensor.. it's right on top of the interchange unit.
        • ash_572
          • Oct 2008
          • 523
          Re: mp4500 jam 66
          today i went back to change the exit sensor situated ontop of the interchange unit and it still jams. any idea?
          • NeoMatrix
            Senior Tech.
            • 3513
            Re: mp4500 jam 66
            This is the MP black and white machine we are talking about ?
            Check under the small front cover located on the upper front panel in front of the interchange and clean the sensors located there.
            There is also the main plug on the duplexer that can pop out from open and closing, this can also give a similar fault on the MP3500.
            Disable tray one and do all your testing from tray 2. Let the forum know if the fault only happens from tray one.
            • sandmanmac
              • 3990
              Re: mp4500 jam 66
              This is the MP black and white machine we are talking about ?.
              Wondering the same thing, since I don't show a jam code 66 on MP4500
              • ash_572
                • Oct 2008
                • 523
                Re: mp4500 jam 66
                yes its a black and white machine. it jams code 66 only when duplexing from all trays. simplex is perfect. duplex unit and interchange units have been changed. sometimes duplexing works ok but most times it jams at the exact same place.
                im also getting a jam 003 from tray one. all feed rollers, torque limiter and feed clutch has been changed. this is also intermittant.
                this is the same type of model as a 3045. not the new mp4000 type
