Aficio 2022 Waste Toner ?
  • iscott
    • Mar 2010
    • 344
    Is there a waste toner bottle on a Aficio 2022? I'm getting conflicting reports....
  • rthonpm
    • Aug 2007
    • 2859
    Re: Aficio 2022 Waste Toner ?
    None at all. Toner and waste toner never leave the PCU. To verify, check the Detailed Descriptions section of the Service Manual.
    • Jomama46
      • 2900
      And that accounts for the blank copies
      sigpic
      A+; Network +; PDI+
      • Eric1968
        • 2458
        Are you using Max OSX? I know that there could be an issue with the SNMP-protocol that is used in OSX. This can cause strange messages to appear. I've seen an error message that the waste ink container should be replaced on a laserprinter (?). Solution is to disable SNMP if possible.
