Got a good fax problem here. Recieve works fine. dialing doesn't. You hit on hook mode, hear dial tone..push button, here the tone but it doesn't stop the dial tone. It will do this all day long. change tone to pulse dial and it works fine. Hooked up handset to the phone line and all is good. Hook handet up to tel on machine and it works fine. It's just when you try to dial on machine using tone dial and not pulse. The phone line is plugged into line jack. replaced FCU to no avail. turned off dial tone detection and no help. Any good ideas on this one?
