full bleed printing
  • sostek
    • May 2010
    • 80
    full bleed printing
    Just a question concerning useage. I'm starting to get alot of customers who ask about full-bleed. Anyone notice machines running any dirtier printing alot of full-bleed?
  • rthonpm
    • Aug 2007
    • 2859
    Re: full bleed printing
    All the time: Ricoh's colour equipment is made for business colour as opposed to production colour. The fusers just don't hold up very well to full bleed runs as they are made to expect a fairly low B/W to colour ratio.
    • ricohpp
      As at today, all laser technology products (regardless of brands), be it office or production cannot do full bleed printing. The most is to cheat the machine by registering the paper as bigger size but we will risk having jam in the fuser area. In digital printing, we always print our documents onto larger size paper and cut it into desired size to achieve the full bleed finished size.
      • rthonpm
        • Aug 2007
        • 2859
        I agree with ricohpp, most full bleed stock I've seen is run on either 11x17 or 12x18 stock and cut down. Full bleed printing on the same size medium you are looking at using will never be successful.
        • Gift
          • Mar 2011
          • 2459
          Full bleed reduces the lifetime of the pm parts and it's not possible at all without a certain leading edge erase (ugly fuser jams on most machines).
          • KenB
            Geek Extraordinaire
            • Dec 2007
            • 3944
            I agree - the only reliable way to get full bleed is to print on a larger size then cut it down.
            Anyone in the production world knows this.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              X2!!!
              Mystic Crystal Revelations
              • teebee1234
                • Jul 2008
                • 1670
                Originally posted by Tonerbomb
                X2!!!
                Agreed, also on some models you will find a full bleed check box in the driver settings but I never mention or promote it. The newer production color models are probably more reliable as they can automatically adjust the paper position F>R as it is processed, keeping the toner overage to a minimum.
