Ricoh Mp6001 sc 401
  • Gesttech
    • Oct 2009
    • 123
    [Misc] Ricoh Mp6001 sc 401
    Hi
    I have a client that has a mp6001. The problem was Sc401, (When user copying few copy then paperjam at fusing section
    occurs & on display it indicate SC401.
    I check the copy, it pale at the end of copy. For me, its may be the Transfer belt connector
    or transfer pcb. I not sure.
    For that i would like to confirm, if it Section of transfer or developer.
    Thanks.
  • fbkhan3
    • May 2012
    • 421
    Re: Ricoh Mp6001 sc 401
    Take out the transfer Unit,clean it up well,make sure contact inside the transfer assembly(transfer roller,bias Roller,Current terminal are connected good and clean).
    If everything is ok then something wrong with transfer belt main connector or transfer powerpack.
    • kyrenecopy
      • Apr 2012
      • 205
      Depending on the age of the belt you may want to make sure there are no pin holes arced into it. This is a common problem. It will give you 401's and 402's.
      Testing 1-2-3, testing, testing. Is this thing on?
