MPC2500 SC543
  • knarfdnul
    • Apr 2011
    • 27
    [Error Code] MPC2500 SC543
    Hi all.
    This maschine makes an SC when idle. Error not present, when we visit. Tried other fusing unit and connector behind fusing unit on chassis is OK. Connectors on PCB off and on - has worked for one week but error is back again now. Going to change PCBs mentioned in service manual tomorrow. Any ideas?
    Kind regards
    Frank
  • Eric1968
    • 2458
    Re: MPC2500 SC543
    Did you upgrade the firmware? I thought there was an RTB out about this one.
    • knarfdnul
      • Apr 2011
      • 27
      Re: MPC2500 SC543
      Hi Eric. Firmware has been upgraded and the maschine was total disassembled and cleaned just before delivery at christmas.
      • Eric1968
        • 2458
        Re: MPC2500 SC543
        Well, then I'm out of ideas.. Good Luck tomorrow!
        • knarfdnul
          • Apr 2011
          • 27
          Re: MPC2500 SC543
          Hi Eric.
          Thanks for info. I have also checked the connector behind the fusing unit, which sometimes has been broken in the plastic around the connectors.
          • Polarbear
            • Feb 2012
            • 1070
            Re: MPC2500 SC543
            Two questions.
            When last did you change the thermistors and do you know it all the lamps in the fusing unit are working?
            I know the second one sounds screwey, but we have had strange problems with mpc machines, and solved it in the end when discovering that one of the lamps don't work.
            Press the GREEN button!!
            • knarfdnul
              • Apr 2011
              • 27
              Re: MPC2500 SC543
              Originally posted by Polarbear
              Two questions.
              Hi Polarbear.
              The first thing I tried was another fusing Unit. Now I have charged thermopile, socket with wires behind fusing, IOB/BICU/PSU PCB. Has run since monday.
              • Polarbear
                • Feb 2012
                • 1070
                Re: MPC2500 SC543
                Have you now discovered what made it work? It would be nice to know.
                • knarfdnul
                  • Apr 2011
                  • 27
                  Re: MPC2500 SC543
                  Hi Polarbear. I have taken all changed parts with me. Will put Them in maschine at workshop for test.
