Aficio 3030
  • Peter Sim
    • Sep 2008
    • 440
    Aficio 3030
    Hi all,
    I wanted to copy prnter/scanner type3030 from SD card to another SD card,can i used sp5873-1(move Exec)?
    Sd card ia already format using panasonic formatter
    Please help.
    Thank you.
  • Polarbear
    • Feb 2012
    • 1070
    Re: Aficio 3030
    Aplimove is only good for merging apps onto one SD card, if you have more apps than slots to install them in.
    Ricoh does not enable you to make copies of SD cards through their machines, and should you install an app SD card into a card reader, it is toast at will not function in the machine afterwards.
    Hope this helps.
    Press the GREEN button!!
