Help please !!!! erro sc400 ricoh mp c2050
  • fbkhan3
    replied
    Re: Help please !!!! erro sc400 ricoh mp c2050
    Oiiii,TDBM.
    Clean or replace the ID sensor,but first you need to check parts yield or life like PCU and ITB(Image Transfer Belt).
    Also happens when parts are expired or done their life.
    for Id sensor cleanings see attachment. but make sure you don't scratch the id sensor.
    hope it help's.
  • sharpmind
    replied
    Originally posted by felipegoes
    Hi, sorry for my english, but i have one problem.
    as i find the sensor and how i can clean him?
    thanks.
    Open the side door. Below the image transfer belt unit you will find black plastic frame with two screws. Remove it. After you remove it, you'll see the ID sensor board.Remove all screws and then pull the ID sensor board slowly.No need to remove the connector. Clean the ID sensors with clean cloth moistened by alcohol.
    Note: Be careful not to touch the image transfer belt while removing the ID sensor board.
    That is easy way..
  • felipegoes
    guest_started_a_topic_y_with_prefix
    thanks.
