Help please !!!! erro sc400 ricoh mp c2050
  • sanjayalk1
    replied
    Re: Help please !!!! erro sc400 ricoh mp c2050
    Start a new thread idiot.
    I dont have problem to open new thread bro....
    replied
    Originally posted by sanjayalk1
    Because i got this error and google leed me this thread,
    And it doesn't help me my error
    And i found the solution on my repair guy.
    So I share it on this thread. Someone can get help on it ....
  • sanjayalk1
    replied
    Originally posted by davel
    This thread is 6 years old, why bother?
  • RicohBoomer
    replied
    Some sc 400 error can be clear following code
    Go to system settings ( press clear mode + 107 and long hold clea/stop),
    Press 33246 #
    0 #
    And exit switch off and on
    I realize this thread got necro'd but just want to quote this and say, don't.
    You are essentially just lowering the treshhold for when the machine spits out an error.
    Just clean the ID sensors instead of doing silly things in the SP Mode.
  • davel
    replied
  • sanjayalk1
    replied
    Press 33246 #
    0 #
  • duplicators
    replied
    Originally posted by Capriolo
    Most of the time is replacing the sensor the best solution.
    Chance developer unit
    Enviado desde mi Moto E (4) mediante Tapatalk
  • Capriolo
    replied
    replied
    Originally posted by bazzbarro
    Hi , I am experience cing error sc400 on richo 232 have cleaned the I'd senser but not worked please tips And hint to sort this, an also noted black toner leaking could it course this?
    Different model. Start a new thread.
  • bazzbarro
    Guest replied
  • Polarbear
    replied
    From past experiences with these machines, I would add the following to cleaning/replacing the id sensors.
    Remove the ITB assembly and remove and clean the metal plate found on the same side as the id sensors (paper feed side).
    With use, this plate becomes contaminated with toner (normally ends up being a dark blue/purple colour. Vibration in the machine causes the toner to fall through the square holes in the plate, right onto the id sensors.
    To remove the plate, remove the 2 screws that hold the plastic handle in place (closest to you), then slide out the metal plate.
    Once cleaned, reinstall the plate, making sure that it sits in the alignment pins, then reinstall the handle and the 2 screws.
    Reinstall the ITB assembly and you are done.
    replied
    Originally posted by sharpmind
    Clean the ID sensors with clean cloth moistened by alcohol.
  • code_52
    replied
    Hi fbkhan3,
    your answer helps me.
    You are great!
  • JustManuals
    replied
    Paul@justmanuals.com
  • Zeldaman
    replied
    Hi there!
    Had this problem 3 times, everytime it was cleaning the sensors & changing the ITB-cleaningunit (machines with high volume).
    Greetings...
