Lanier LD 160c
  • dgrow
    • Feb 2011
    • 26
    [Electrical] Lanier LD 160c
    Hello All,
    I have a Lanier LD 160c that will not power on. The main power light glows green but nothing happens after that. The machine will not boot up at all-no sound, nothing! We've tested the machine for AC in and out which shows there is power in and out. Fuses look fine. We haven't found any voltage going to the high voltage board. Any suggestions?!?!
  • kyrenecopy
    • Apr 2012
    • 205
    Re: Lanier LD 160c
    NVRAM, main power supply, IOB board. Check for shorts in the 24v lines (sensors etc.) especially in the fuser and Large capacity trays
    Testing 1-2-3, testing, testing. Is this thing on?
    • teebee1234
      • Jul 2008
      • 1670
      Re: Lanier LD 160c
      Do the easy checks first. Try and power up with any accessories disconnected (finisher, adf, lct) and doors open. If no change, disconnect the HDD and try again. From there, I would then disconnect all output connectors on the PSU and plug them back in one at a time to try and find a load that may be shorting. Generally, the HDD, Polygon Mirror Motor and Fuser are known to be culprits but a pinched wire anywhere could cause this.
      • JustManuals
        • Jan 2006
        • 9919
        Re: Lanier LD 160c
        The manual is listed as the Ricoh 2060.
        Paul@justmanuals.com
        • Shadow1
          • Sep 2008
          • 1642
          Re: Lanier LD 160c
          I've also seen several blown power supplies here recently. That's hard to test, because with all the connections undone they usually only output a single 5V supply, waiting for a signal from the IOB to switch on the rest of the voltages. Best luck is to disconnect everything but the IOB (or wherever the signal comes from on whatever model you're working on) and then disconnect everything else from the IOB and see if it fires up. If it's still dead bet on the power supply, but it still could be an IOB at that point - or idiot engineering needing the BCU and / or controller hooked up as well.
          73 DE W5SSJ
