C2550 finisher
  • Jomama46
    • 2900
    C2550 finisher
    I remember seeing either a TSB or picture that someone posted of a solution to a problem in this C2050 finisher. It had to do with filing or cutting something so that the belted (exit?) rollers would make better contact with the paper when pulling them back into the stapler unit.
    I think it had to do with skewed copies in the jogger unit.
    I have searched this site and my computer and cant find anything.
    Anybody remember something about this?
    sigpic
    A+; Network +; PDI+
  • totoro
    • 568
    Re: C2550 finisher
    Is this what you're looking for?improper stacking.pdf
    Totoro
    • Jomama46
      • 2900
      Re: C2550 finisher
      very interesting totoro, not what I remember but I beleive its the same idea. thanks
      that must be a scan I wonder if anyone has the original, the pix is not too clear but I really appreciate the input
      sigpic
      A+; Network +; PDI+
      • totoro
        • 568
        Re: C2550 finisher
        If you take the finisher out and look at it from the input side, you can see the grey belts in the scan. The belts are are held at a certain height by the 2 white skids on either side. That is what they are pointing at in the last scan. Take a pair of wire cutters and cut 1-2 mm off the bottom of the skids to lower the grey belts down. This should take care of your stacking problems. It is a little awkward to get to, but I have used this twice with good results.
        Totoro
        • Jomama46
          • 2900
          Re: C2550 finisher
          thanks again
          sigpic
          A+; Network +; PDI+
