duplicate 2 same copy on ifax
+ More Options
Posts
  • sasa12u
    • Nov 2011
    • 39
    i had encounter 1 problem regarding ifax for 3224c,i had 1 customer using ifax to rx and tx the fax but the problem is in the pc will create same copy/duplicate same copy at different time once receive the fax. any setting can adj.
    pls adv.thank
  • Jomama46
    • 2900
    Re: duplicate 2 same copy on ifax
    are you saying" internet-fax" or "lan fax"?
    If the transmitter detects or thinks it detects that a fax wasnt received completely ,it will resend. There may be a setting to prevent that depending on which system you are talking about.
    sigpic
    A+; Network +; PDI+
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • sasa12u
        • Nov 2011
        • 39
        Hi jomama,
        What is different internet fax and lan fax????
        • Jomama46
          • 2900
          internet fax or i-fax is sending a fax over a network instead of a phone line.
          Lan fax is sending a fax from your computer to the mfp then using the mfp's modem out on the phone line.
          sigpic
          A+; Network +; PDI+
          • sasa12u
            • Nov 2011
            • 39
            Hi jomama,
            I get it,thank
