How to disable scanner report on ricoh aficio 3030?
  • Ricoh888
    • Jan 2012
    • 10
    Hi Folk! I got some issue to ask you guys here. How to disable scanner report on aficio 3030? as far as I know, I never heard and see the scanner report will be print out from the machine. for fax report I know how to disable it but for scanner report I don't know how to disable the report..
    Need help from you guys..
  • mikadonovan
    • May 2008
    • 2931
    Re: How to disable scanner report on ricoh aficio 3030?
    This is from a mp6001, but it should be the same. This is from scanner user tools. Bottom of the screen, should be set like this.
    NEVER ASSUME ANYTHING
    • Archiviobologna
      Hi, everyone.
      Mp6001 panels seems to be quite different...
      Anyone can advice about disabling the scanner report on the actual 3030 machine?
      Many thanks
      Piero
      • nmfaxman
        • 1702
        3030 is the same under scanner features.
        RTFB.
