Eror code SC672 MP2510
  • Peter Sim
    • Sep 2008
    • 440
    Hi all,
    Need help.
    Fews day back machine was ok ,this morning switch on power,please wait and then sc 672.
    Is basic machine.
    Is due to firmware update or controller board ?
    Thank you in advance
  • Polarbear
    • Feb 2012
    • 1070
    Re: Eror code SC672 MP2510
    Check the firmware first:
    This is en extract from a firmware RTB:
    1.01 D0065931B November 2006 production
    1.00 D0065931A July 2006 production
    Version Symptom Corrected
    Ver 1.01 Symptom corrected:
    1. SC672 may occur when the machine recovers from Auto Off mode.
    Also:Ver 1.22
    1. SC672 occurs when the main switch is turned ON if SC Auto
    Reboot Mode is already enabled.
    Press the GREEN button!!
    • JustManuals
      • Jan 2006
      • 9931
      Paul@justmanuals.com
      • MOSSY BOY
        • Aug 2010
        • 16
        Hi, if this device has a HDD on it take it off or just disconnect it.
        try booting up m/c and if ok then your HDD needs formatting, if not its a new controller pwb.
        If a format is required,this can be done using a caddy, but remember DO NOT ASSIGN A DRIVE LETTER!!
        if you have had anything in the address book it will be gone i.e scan to email tab or to folder, fax or any docs in the doc server.
        hope this is of help...
        • Shadow1
          • Sep 2008
          • 1642
          In my experience this is almost always a bad HDD - chances are a computer wont even detect it... and if it does you won't likely be able to format it.. and even if you do it won't likely last a week. Just replace it.
          Also seen lots of bad controllers here lately, bad LCDC boards, and on occasion a pinched harness to the OP panel.
          73 DE W5SSJ
