Cl 7000 second side issue
  • DINGO
    • 661
    hi friends.
    i do not have much experience in this copier, i work more with sharp copiers.
    So, i need your help, because i have a cl 7000 that when i do duplex copy like 2=2 or 1+1=2 mode,
    the second side is slightly offset laterally about 0.05 mm, and the result is, in one border make a black line, and in the other border cuts the copy.
    i do not know if is a code adjust like in sharp, or another issue.
    thanks
  • sandmanmac
    • 3990
    Re: Cl 7000 second side issue
    Go to user tools, copier/document server, edit, then set all the duplex margin settings to '0'
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • DINGO
        • 661
        thanks friend, was the solution.
        regards
