Set default function on Savin C6045/Ricoh 3260
  • prusierra
    • May 2012
    • 15
    I've looked in the configuration and tried to find online but I was wondering if there is a way for the 'default' function of the device to be set to Scanner instead of copier.
    We use access codes and as soon as it times out, it defaults to copier - we just want it to default to scanner instead.
    Thank you.
  • sandmanmac
    • 3981
    Re: Set default function on Savin C6045/Ricoh 3260
    Don't over complicate things:
    user tools/ system settings /function priority
    • kyrenecopy
      • Apr 2012
      • 205
      User tools, General features, function priority, set to scanner
      Testing 1-2-3, testing, testing. Is this thing on?
      • prusierra
        • May 2012
        • 15
        [facepalm] that was easy...
        Thanks!
