Scan to email on Aficio 2000
  • poz31
    • Aug 2006
    • 86
    tried to follow the white papers.....mmmmm
    read some post (Ricoh wont work with SSL)
    I usually work with KonicaMinolta...
    but costumer wants to scan at 300dpi which minolta BW does not have...
    Am I missing something (of course) but what???
    Trying to set up scan to email on Ricoh MP2000
    72.249.41.52)
    I'm using lavabit cause ricoh does not work well with gmail...
    on file transfer ance the ip and port are set up it wont comunicate..
    Here are my settings:
    Administrator E-mail Address : XXXXX@hotmail.com
    Reception
    Reception Protocol : SMTP
    E-mail Reception Interval : On
    : 15minute(s)
    Max. Reception E-mail Size : 2 MB
    E-mail Storage in Server : Off
    SMTP
    SMTP Server Name : 72.249.41.52
    SMTP Port No. : 25
    SMTP Authentication : Off
    SMTP Auth. E-mail Address : bslscan@lavabit.com
    SMTP Auth. Encryption : Auto Select
    POP before SMTP
    POP before SMTP : Off
    POP E-mail Address :
    Timeout setting after POP Auth. : 300 milli-second
    POP3/IMAP4
    POP3/IMAP4 Server Name : 72.249.41.52
    POP3/IMAP4 Encryption : Auto Select
    E-mail Communication Port
    POP3 Reception Port No. : 110
    IMAP4 Reception Port No. : 143
    SMTP Reception Port No. : 25
    Fax E-mail Account
    Fax E-mail Address :
    E-mail Notification Account
    E-mail Notification E-mail Address
    : XXXx@hotmail.com
  • Eric1968
    • 2458
    Re: Scan to email on Aficio 2000
    The Aficio MP2000 doesn't support SSL, so scanning to the Gmail SMTP-server isn't possible. Just put in the SMTP-server adress (IP-adress or Hostname) and the the Administrator Email adress. In User Tools - System Settings - File Transfer set the administrator email adress as recipient email adress. If Lavabit.com uses SSL or some other encrypted connection, you can't use that because this machine doesn't support it.
    • sandmanmac
      • 3964
      If you have no access to an SMTP server without encryption then the only option I know of is to use a gmail account and install Stunnel per instructions attached, that will allow the mail to flow. It does works great, but do keep in mind that the PC with stunnel installed must be "on" and also have a static IP
      You can download from here: stunnel: stunnel - multiplatform SSL tunneling proxy
      Installation instructions for use with Gmail here:Stunnel - GMAIL Setup.pdf
      P.S. Be sure to turn off Reception, and turn off Max. email size, or at least crank it up, or you'll have nothing but grief
      • sandmanmac
        • 3964
        As I read through your post again, I had a couple of questions. I'm not familiar with lavabit, so does it use 'SSL' or 'TLS'? if not, then it should work.
        But I'm sure it must require authentication, so you probably need to turn that on and enter the email password. Also, have you entered the proper DNS, and gateway on the copier?
        • poz31
          • Aug 2006
          • 86
          now when you said :"the only option I know of is to use a gmail account and install Stunnel" what about on companies that do not have they own server?? (I'm in the border with mexico and the fowarding companies require to scan at 300DPI)
          "Also, have you entered the proper DNS, and gateway on the copier?"
          • sandmanmac
            • 3964
            I might sound silly, but the machine is printing so I’m on the network (is that what you are refering to?)
            do you any other email account with out the SSL or TSL??
            Thanxx for the guidance
            I did a little research.
            Lavabit uses encryption, so it won't work for sure.
            You don't need a 'Server', you just need to designate a PC to 'act' as a server, and set a static IP to it, and leave it on. Printing , Scanning to folder etc. is possible without setting the proper DNS, but for scan to email, it's a MUST
            • sandmanmac
              • 3964
              I just set up a yahoo.com address successfully. No encryption needed
              Again, make sure you have the proper DNS, gateway, etc. input into the copier interface settings first.
              Setup a Yahoo.com address.
              Then just input the following info and it should work:
              Administrators email Address: (whatever you want)
              Reception
              Reception Protocol : POP3
              E-mail Reception Interval : OFF
              SMTP
              SMTP Server Name : 98.136.185.95
              SMTP Port No. : 587
              SMTP Authentication : ON
              SMTP Auth. E-mail Address:
              yourmail@yahoo.com
              SMTP auth username: (your yahoo user info)
              SMTP Auth. Password: change (enter your email password)
              On the Copier. Go to user tools - system settings - file transfer - auto specify senders name- turn on (this will use the administrator email you programmed above as the sender)
              Go to the address book and program the Name and enter desired email addresses
              Works for me on an identical machine.
              Good luck
              • poz31
                • Aug 2006
                • 86
                Thankxxxx it worked like a charm!!!!
                One more time, I really appreciate your help !!!!!!
                • sandmanmac
                  • 3964
                  Say it like you mean it!...LOL (Kidding of course).
                  Happy I could help, and glad it worked out for you. That's what this place is all about.
                  • poz31
                    • Aug 2006
                    • 86
                    I know there are some options I can change before I send anemail, but is there a way this could be set up and be fix so the costumers willnot have to deal with this every time they scan (changing these options)?
                    • sandmanmac
                      • 3964
                      To set 300dpi default: user tools - scanner features - scan settings- resolution- 300dpi -ok
                      To set PDF default: user tools -scanner features - send settings -file type priority - multi-page pdf -ok
                      • sandmanmac
                        • 3964
                        but on this one Aficio MP 2000
                        the user tools has two options "counter & system settings" and on system setting it does not show up a scanner menu...
                        is there a setting I need to turn on to display the scanner menu???
                        Use the "arrow keys' to toggle up and down the menu
                        • poz31
                          • Aug 2006
                          • 86
                          sorry I deleted 'couse that was bad anyhow ...
                          one more time thank you a lot
                          • COPIERMAN
                            • Jun 2009
                            • 559
                            user tools/ scanner/ send settings/file type priority here you can tell it to be a tift, pdf or jpeg file you can tell it in settings also dpi to use. Ricoh website you can get operation manuals ricoh-usa.com/downloads in search tell it what model and select drivers/ manuals or brochure on copier
                            • poz31
                              • Aug 2006
                              • 86
                              Re: Scan to email on Aficio 2000 On yahoo account
                              ok so it's been working fine but..... I can no longer logged into the yahoo accounts I set up 6 machines different companies...
                              Its seems yahoo block me or something like that is tehre a way around this..
                              (the account were working fine but this morning all failed... I did on one costumer set up a new account and viola it worked)
                              is tehre any waya round it like the use of anotehr email account???
