Ricoh MP 2550 fusing issue smearing
  • Rick
    • Mar 2007
    • 277
    This unit is not fusing intermittently . I replaced the upper fuser and lower pressure roller and everything is in its proper place but ocassionally it doesnt fuse the toner . Any ideas any one ?
  • Zeldaman
    • Mar 2011
    • 946
    Re: Ricoh MP 2550 fusing issue smearing
    Hi there!
    Thermistors new, holders for pressureroller not bend? Then check the lower frame of the fuser. We had a desease with this parts when one (sometimes both) holders for the fusingrollerbearings were broken.
    Greetings...
    • Jomama46
      • 2900
      whole page is not fused or just in spots? OEM toner?
      I would start with the thermistors.
      sigpic
      A+; Network +; PDI+
      • Gift
        • Mar 2011
        • 2459
        Check if the engine FW is up-to-date - I'm not shure if there was an official change but it's a start. Other things you can try out: Set the paper type to middle-thick, activate fuser-idling.
        • Rick
          • Mar 2007
          • 277
          I only use oem toner and I just changed the thermisters and I will try the fuser idling . Thanks
          • sandmanmac
            • 3981
            Had this recently myself, and turning on fuser Idling did the trick
            • JustManuals
              • Jan 2006
              • 9838
              Paul@justmanuals.com
              • rsyarcia
                Hair Straightener Tech
                • 711
                We have this problem, we changed the fusing unit assy,boards,set fusing idling and updated the firmwares but no improvements. If you notice after unfused copies, when you remove the fusing unit and put it back the copy is good. What you can do is to check the fusing unit maybe it is moving during operation.See the logs on the machine for any SC sodes.
                Nobody is perfect..
